TwinTurbo.NET: Nissan 300ZX forum - More Transmission Problems
Subject More Transmission Problems
Posted by BlackTT91 on May 13, 2008 at 1:59 AM
  This message has been viewed 214 times.
Message Experiencing two problems which i believe are related, since they started at the same time. My auto transmission is slipping badly and will not go into overdrive. Also there is white smoke coming from under the car it seems like up through the back of the engine.
Ive changed the fluid and filter and test drove it and the problem is stil happening nothing changed. Their is alot of leakage it looks like from down their and the test pipes are covered in a fluid (im pretty sure its leaking ATF) that seems to be running down them from front backwards.
Im not to sure of how everything works with the auto transmission but what i think is that a have a cracked/cut/broken line that the transmission fluid is leaking from and causing their to be no/little pressure in the system therefore it cannot shift properly. And also the leaking fluid is running onto my exhaust causing the white smoke from under the car.
All im really asking for is what lines are there to check that could break or where could this leak be coming from. Also if thisanalysis sounds right or not?
