TwinTurbo.NET: Nissan 300ZX forum - The truth, based on experience...
Subject The truth, based on experience...
Posted by .z on May 12, 2008 at 3:16 AM
  This message has been viewed 210 times.
In Reply To Any real difference with the 96TT's VS previous years? posted by jayru on May 10, 2008 at 07:09 PM
Message A lot of people will steer you away from the 96 because of tuning issues. Here is the scoop. 96tt were set to a lower boost by about two pounds from the factory to satisfy emmisions watch dogs and the like. Turn the boost back up, you are at 300hp. The lack of VTC is true. Nissan addressed this with a lumpier cam. Listen to the 96 idle, you can hear the difference from previous years. You will make the same power, just higher in the rev band. The rear o2's, as long as you have bungs welded into the test pipes to keep them in the exhaust stream, they will not throw a code. The only exception to this is if you have a bad tune. If anything, the extra o2's provide oppurtunity for a tighter a/f mixture. ope this helps.
DP
"Yes, I know my car is still running"
