TwinTurbo.NET: Nissan 300ZX forum - cylinder 2 misfire...
Subject cylinder 2 misfire...
Posted by onewheelf4 on May 10, 2008 at 9:21 PM
  This message has been viewed 795 times.
Message hi i posted a while back about having a misfire problem. all of my coil packs are fine so its obviously an injector problem. But i was wondering if this has happened with anyone else. If you start the engine when the car is cold the number 2 cyl will fire and run fine no problems. you can disable the cylinder and the engine rpm will drop which shows that it is working fine. then as the engine gets up to operating temp the cylinder will go out and stop receiving fuel. sometimes the problem occurs, some times it does not. its getting aggravating. i am going to pull the plenum and change the injector and the the harness clips but just wanted to know if this has happened with any other members and what they did to fix the issue. Thanks guys !!
