TwinTurbo.NET: Nissan 300ZX forum - this is the boomslang with NEO sub-harness built in
Subject this is the boomslang with NEO sub-harness built in
Posted by ZonaZ on May 10, 2008 at 11:36 AM
  This message has been viewed 276 times.
In Reply To Couple of clarifications posted by ThunderZ on May 10, 2008 at 08:59 AM
Message There is no blue wire. The pic shows the sub-harness.
The boomslang has the afc neo harness already wired in. The basic NEO wiring is done with the harness. Yellow is already in pin 27 ecu side. The white wire is already in pin 27. Went back and checked my wiring from boomslang, this is how it is wired for the NEO:
yellow - pin 27 - air flow meter - ECU side
white - pin 27 - air flow meter - harness side
brown - pin 60 - ground - ECU side
black - pin 60 - ground - Harness side
red - pin 59 - ignition power - harness side
purple - pin 59 - ignition power - harness side
grey - pin 38 - throttle signal - harness side
green - pin 7 - rpm (tach) - harness side
The purple wire is going to the ig power, I know in the post that it shows purple going to knock sig but that is a AFCII. The NEO wiring diagram book, pg 28 N4-a, shows no connections to knock sig.
Has anyone actually wired a dual maf with a boomslang with a NEO sub-harness?
thx
John
