TwinTurbo.NET: Nissan 300ZX forum - Couple of clarifications
Subject Couple of clarifications
Posted by ThunderZ on May 10, 2008 at 8:59 AM
  This message has been viewed 226 times.
In Reply To Wiring dual maf w AFC NEO w Boomslang harness posted by ZonaZ on May 09, 2008 at 10:01 PM
Message yellow - pin 27 - air flow meter
You CUT the boomslang MAS wire. Yellow from the AFC goes to PIN 27 of the ECU
white - pin 27 - air flow meter
Wrong, does NOT go to pin 27. This goes to the 1st MAS
The BLUE wire goes to the 2nd MAS
The new Ground goes to the Ground
brown - pin 60 - ground
Put this 1" away from ECU
black - pin 60 - ground
Put this 1/2" away from ECU
red - pin 59 - ignition power
I like to run this to the fuse box w/ the proper tap since the Boomslang is such a thin wire
purple - pin 59 - ignition power
Wrong, this is the knock sensor connection
grey - pin 38 - throttle signal
green - pin 7 - rpm (tach)
