TwinTurbo.NET: Nissan 300ZX forum - Wiring dual maf w AFC NEO w Boomslang harness
Subject Wiring dual maf w AFC NEO w Boomslang harness
Posted by ZonaZ on May 09, 2008 at 10:01 PM
  This message has been viewed 460 times.
Message Here is where the AFC NEO Boomslang harness is going:
yellow - pin 27 - air flow meter
brown - pin 60 - ground
black - pin 60 - ground
red - pin 59 - ignition power
purple - pin 59 - ignition power
white - pin 27 - air flow meter
grey - pin 38 - throttle signal
green - pin 7 - rpm (tach)
After I solder on my shielded wire, splice (or is this a cut?) the white to the white (or yellow) on pin 27. Splice the black wire to pin 26 MAF sig ground (not listed above) or to pin 60?.
Would that work or do I need to do something else? thanks for any details\info.
Here are the maf wires, already have maf power and ground soldered in. Have shielded wire just need to solder and run to ecu area and boomslang harness.
Boomslang harness:
John
