TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Help getting car started with relays.
Subject Re: Re: Help getting car started with relays.
Posted by bobluhrs on May 09, 2008 at 2:59 PM
  This message has been viewed 165 times.
In Reply To Re: Help getting car started with relays. posted by bobluhrs on May 09, 2008 at 02:50 PM
Message ...after you see the flash codes, and before anything else, turn the slotted screw CW again, wait few seconds, and CCW fully again to get back into running mode. the flash codes should stop at that point. Code 21 sometimes, can mean a bad PTU, but not definite, I am told...
:Jumping the relays should not harm anything. Jumping means connecting #3 pin to #5 pin, that's what you connected, (right?). You tested the blown relays using 12 volts across 1, 2 (right?) and you got no "click" so that's how you knew the relays were not working (right?).
:When you jump the relay (pin 3 to pin 5) all you do is what the relay used to do.
:If you have a meter, check the volts to body-ground on pins 1,2 of the ignition relay socket, let me know, please, as I'm debugging a similar situation in my own TT.
:I have ordered a new PTU and have it onhand. If mine's ok, I'll still swap and relocate just to have a more reliable car, even if it's not the problem.
:My situation started when an anti-theft unit went in and cut two orange wires leading into the fusebox under hood. I now don't know if he crossed them up or not, but I'm getting +12 volts to ground at BOTH 1,2 in the ign relay socket, with the key on OR off!!! Nothing can flow across that so it might be crossed wires in your case.
:I'm not suggesting what's wrong with yours, specially since I don't know my own, but the PTU is a known failure in these beasts, and the harnesses to it aren't any bargain either.
:bob
::So under the hood in the Fuse box, theres the EGI and IGN two green 12Volt Relays. Both of mine blew at once how I dont know. Then I jumped the EGI and IGn relays out just to see if it would start and it did, but soon after died out. So I went and bought two relays same but not sure if they were 12Volts, it didn't specify on the box or relay. But now the car won't start could this be because these relays are no good? Should I order the Factory 12Volt Green Relays. Or from me jumping the relays out cause my PTU to go? Any help would be appreciated thanks!
