TwinTurbo.NET: Nissan 300ZX forum - I'd just do a meter continuity check between the ECU
jzack
on May 08, 2008 at 6:14 PM
Is it possible you've got a pinched/cut wire from doing
posted by Dave N
on May 08, 2008 at 10:20 AM
pins and the O2 connector. Should be easy to tell if the ECU pinout is right or the harness or connector has a connection issue on one of the lines???
no right 02 sensor signal
vorpalZ
23:04:03 05/07/08
What about doing the O2 self diag directly from the ECU? (n/m)
Dave N
00:29:20 05/08/08
when I set the ECU in Mode II and run @ 2000 RPM
vorpalZ
07:47:40 05/08/08
Dave N
10:20:22 05/08/08
I'd just do a meter continuity check between the ECU -
jzack
18:14:31 05/08/08
In vorpalZ's OP he mentioned he already did the continuity
Inzane
10:02:57 05/09/08
Damn, I wish I'd known you were doing your harness install.
Inzane
14:19:45 05/08/08
