TwinTurbo.NET: Nissan 300ZX forum - With your mods I would just stick with the stock injectors.
Subject With your mods I would just stick with the stock injectors.
Posted by 5280Z_nightstalker on May 08, 2008 at 10:49 AM
  This message has been viewed 146 times.
In Reply To injector replacement-- which injectors? posted by jm12rr on May 08, 2008 at 10:33 AM
Message If you want to get nasty then maybe go with the stock TT injectors but youll have to upgrade your ECU with a chip to tune for those. I wouldnt upgrade the fuel rails since all you have is basically a stock NA. You will need injectors, both set of O-rings (there is a lower and upper O-ring on each injector). If your going to pull the plenum you will also need a plenum gasket.
It does really all depend on your plans for the car and the money your willing to spend. You can try to find some used good 370cc (stock TT) injectors, or if you want to do new you can try Deatsch Werks as they are not that expensive and many have tried them here and are reporting good results about them.
Hope that helps and also I would buy new injector wiring clips and splice those into the harness that way you know your good there too.
