TwinTurbo.NET: Nissan 300ZX forum - I agree with TTFairladyZ - reusing the JDM oil pan was not
Subject I agree with TTFairladyZ - reusing the JDM oil pan was not
Posted by Dave N on May 08, 2008 at 12:36 AM
  This message has been viewed 206 times.
In Reply To oil pan leaking from small hole due to a jdm engine sitting posted by pearlyellowtt on May 07, 2008 at 07:32 PM
Message a wise choice. There are numerous cases cited here where the abuse to the oil pan during shipment causes problems far worse than a leak.
Therefore, I strongly recommend replacing the oil pan (and pick up tube) if you want to avoid a possible oil starvation problem, or additional leaks.
Assume for the moment that the oil pan is not dented and all is OK in that regard, I would not suggest using JB weld to fix the leak. Regular welding would probably be your best bet. But, I really think you're better off with replacing the oil pan.
Good luck,
Dave
Sig Quotes:
"Your sausage scares me!" - TT-XTZ 6/13/05
"Or he's having a rough week like the rest of us and decided to take out his agressions of not being breast fed on me." BigTDogg 15:45, 09/25/03
"Pick her up from day care and take her to Dairy Queen for a snow cone." YugoBernie 1/7/04
of course those are canadian bannings and beatings, which after the conversion rate is really only a "hey! stop that!" Chris(NJ) 1/14/04
see the green "n" next to my name? what's COZ? (n/m) - 300zx88 8/11/04
