TwinTurbo.NET: Nissan 300ZX forum - make sure those are 5 bolt dp's
Subject make sure those are 5 bolt dp's
Posted by gt300zxtt on May 07, 2008 at 11:37 PM
  This message has been viewed 106 times.
In Reply To Need Help/advice:Turbo upgrade..garett 600bb's posted by 300z-shaat on May 07, 2008 at 09:46 AM
Message you will probably need a whole assortment of gaskets and hoses. for example, oil drain tubes, water lines, all associated plenum gaskets, injector-plenum seals, fuel lines (hopefully the 600r's include the gaskets, drain tubes, and oil supply lines like they are supposed to)...to name a few.
you could also do egr and plenum water line delete if they have not already been done. the possibilities are endless.
