TwinTurbo.NET: Nissan 300ZX forum - Wow...I thought you'd get some help from those guys.
Subject Wow...I thought you'd get some help from those guys.
Posted by ThunderZ on May 07, 2008 at 9:38 PM
  This message has been viewed 135 times.
In Reply To Spoked to a JWT Tech posted by nismo_boost31 on May 07, 2008 at 01:31 PM
Message Since you have no leaks, code 55, and everything is checking out within spec, I would start by bypassing the AFC. I've seen it cause strange readings. It might be good to re-initialize.
Then, if that is not helpful, start replacing parts w/ known good parts that impact A/F:
MAS or MASs
FPR - unless you have a guage that shows it rises properly
Epromm if you have the stock one- turn down boost, go back to single pop
Whatever you do, do one thing at a time to isolate the problem.
