TwinTurbo.NET: Nissan 300ZX forum - Usually a Check Engine light
Noncon
on May 07, 2008 at 7:03 PM
Symptoms of an inoperative ECU chip???
posted by nismo_boost31
on May 06, 2008 at 10:06 PM
Are you using one of the diagnostic software i.e Conzult? If so what is the A/F Alpha when running lean? If it is high (above 105) it means the ECU sees the lean condition and is trying to adjust for it, so ECU is doing what it is suppose to.
Have you checked the O2 sensors?
KJ
nismo_boost31
22:06:07 05/06/08
I'd call JWT and ask for their opinion. When this started
ThunderZ
06:12:49 05/07/08
Spoked to a JWT Tech
nismo_boost31
13:31:46 05/07/08
Wow...I thought you'd get some help from those guys.
ThunderZ
21:38:29 05/07/08
Replaced all fuel related parts, bypassed AFC, even
nismo_boost31
22:45:42 05/07/08
You have a spare chip if you did the JWT deal. Swap in
ThunderZ
09:13:52 05/10/08
Have you checked fuel pressure? (n/m)
Fast300
12:28:20 05/07/08
Fuel pressure is dead on & fuel system is clean (n/m)
nismo_boost31
13:19:30 05/07/08
Usually a Check Engine light -
Noncon
19:03:31 05/07/08
Using techtom for injector speed & MAF voltage
nismo_boost31
22:42:38 05/07/08
Re: Using techtom for injector speed & MAF voltage
Noncon
22:10:09 05/08/08
Maybe the JWT chip is not doubling the MAF signal
nismo_boost31
22:51:36 05/07/08
EPROMS do not just go bad unless you touch them with static
Devi13
03:36:15 05/09/08
I have checked everything
nismo_boost31
09:10:56 05/09/08
