TwinTurbo.NET: Nissan 300ZX forum - Synthetic molecules are smaller and more uniform so
Subject Synthetic molecules are smaller and more uniform so
Posted by doug8867 on May 07, 2008 at 8:08 AM
  This message has been viewed 141 times.
In Reply To Question about Reg Oil/Synth & turbos.. posted by Mike87T on May 06, 2008 at 09:54 PM
Message they leak past old seals where dino oil did not. However, sometimes over time
the synthetic can return the pliability to the old seals and then they seal up the
leak.
Synthetic is definitely better in the long run for turbo life, so you might try
running the synthetic a bit longer to see if the leak subsides. However, if the
smoke is really annoying then you might try switching to a synthetic blend to
see if that helps. Otherwise you'll probably have to go back to the dino oil.
