TwinTurbo.NET: Nissan 300ZX forum - Symptoms of an inoperative ECU chip???
Subject Symptoms of an inoperative ECU chip???
Posted by nismo_boost31 on May 06, 2008 at 10:06 PM
  This message has been viewed 462 times.
Message I am just wondering if my JWT chip is taking a crap. My car is running lean anytime the car goes above 3k. After 3k the wideband shows an A/F 14.3 to 15.2 The higher the boost, the leaner it gets. The car idles and runs great excluding the lean part. By the time you reach 12 psi the car starts to stumble, below that it pulls fine. I have spent 3 months going over my car I can’t find anything. It has the proper fuel pressure, switched CAS and MAF, bypassed the AFC, tried a 40% correction on the AFC, resistance on the injectors are within specs, and the MAF voltage and Injector speed (msec) are all within specs according to the manual at idle and 2k. I have checked all connections to injectors and connections to the ECU. So back to my question, what kind of symptoms will a bad Eprom chip show??????
