TwinTurbo.NET: Nissan 300ZX forum - Stuck or Bent Valve?
Subject Stuck or Bent Valve?
Posted by Dougiefresh000086 on May 06, 2008 at 7:07 PM
  This message has been viewed 166 times.
Message My Z has very bad hesitation, idle and seems to be running on 5 cylinders. I traced it to the #6 cylinder since I can unplug the coil and it has change on the motor. I replaced the injector as well as the connector on this cylinder since both we badly corroded. There is also a really bad exhaust tap from this side "driverside" exhaust. Does it sound like im doomed with a stuck or bent valve, Any input/help, thanks, It is a 90 TT, 102K miles.
