TwinTurbo.NET: Nissan 300ZX forum - Mine does this as well. My subframe bushings are
Subject Mine does this as well. My subframe bushings are
Posted by en5 on May 06, 2008 at 4:40 PM
  This message has been viewed 134 times.
In Reply To Body movement over 50mph. posted by w8lifter4 on May 06, 2008 at 03:47 PM
Message In pretty bad shape, and I'm hoping that when I get a chance to install some subframe spacers it will relieve the issue.
From outside it doesn't really look like anything and the tires definitely do not break loose, the body just wiggles laterally a tiny bit. I have dropped the subframe before and replaced the differential as well as a CV shaft and the only indicator I've seen is the bushings are pretty poor.
Do you get a little wheel hop when your tires spin? I do, which in my mind also indicates subframe bushings are the culprit.
