TwinTurbo.NET: Nissan 300ZX forum - second bleeding both points.
Subject second bleeding both points.
Posted by gt300zxtt on May 06, 2008 at 3:48 PM
  This message has been viewed 135 times.
In Reply To Probably still air in it. Did you bleed the fender line posted by Audioquest on May 06, 2008 at 01:58 PM
Message i use a handy vac, and have someone else top it off. since the reservoir is so small, it does not take much to bleed the reservoir down and introduce air. and as soon as that happens, you have to start all over again. having an assistant keeps you from bleeding 2 ounces from the slave cyl, running back to the top and refilling, then going below again to rebleed, etc. also, teflon tape the bleeder screws so that you dont get tiny air bubbles from the bleed threads which could be confused with air in the lines.
i also use the handy vac to pull any excess fluid from reservoir from overfilling, they are well worth the money.
