TwinTurbo.NET: Nissan 300ZX forum - Re: pcv reroute possibly
Subject Re: pcv reroute possibly
Posted by 300z-shaat on May 06, 2008 at 3:19 PM
  This message has been viewed 120 times.
In Reply To pcv reroute possibly posted by gt300zxtt on May 06, 2008 at 03:02 PM
Message :another possibiltiy: amsoil has bypass oil filter kits with 2 micron filtration that they claim is like changing your oil every ten minutes (6 quarts filtration every ten minutes). on one of the kits, you tap a t fitting to the opsu port, lines run to the filter, then through the filler cap where it runs back into the oil system.
:in any case, you need to trace that line and see where it ends up. could run to your pcv valves, might run elsewhere.
actually its not connected to anything..or linked to anything..the pipe is coming out from the top of the oil cap and then on the end of the pipe..theres that small filter thing..from which oil is dripping out
