TwinTurbo.NET: Nissan 300ZX forum - when the car first starts up
Subject when the car first starts up
Posted by gt300zxtt on May 06, 2008 at 3:14 PM
  This message has been viewed 201 times.
In Reply To It is correct at first, 35-36 psi at idle (n/m) posted by Broke_as_**** on May 05, 2008 at 09:03 PM
Message it should be higher like 40psi+ iirc. after it idles for a bit it drops down. 25psi seems way low. are you using a mech or elect fuel press gauge. if its elect fuel pressure gauge, maybe its fuel pressure related. if its mechanical, than swap out your fuel pump controller with another one and see if it helps.
