TwinTurbo.NET: Nissan 300ZX forum - pcv reroute possibly
Subject pcv reroute possibly
Posted by gt300zxtt on May 06, 2008 at 3:02 PM
  This message has been viewed 156 times.
In Reply To HELP!Oil/smoke coming out from engine bay! posted by 300z-shaat on May 06, 2008 at 10:39 AM
Message another possibiltiy: amsoil has bypass oil filter kits with 2 micron filtration that they claim is like changing your oil every ten minutes (6 quarts filtration every ten minutes). on one of the kits, you tap a t fitting to the opsu port, lines run to the filter, then through the filler cap where it runs back into the oil system.
in any case, you need to trace that line and see where it ends up. could run to your pcv valves, might run elsewhere.
