TwinTurbo.NET: Nissan 300ZX forum - You need to know how to remove it?
Subject You need to know how to remove it?
Posted by doug8867 on May 06, 2008 at 2:57 PM
  This message has been viewed 210 times.
In Reply To pic request! removing outter window slider bolt (n/m) posted by apostrophe28 on May 06, 2008 at 02:50 PM
Message Pry out the round bolt cover on the outside of the door using a flathead
screwdriver in the notch for it. Pry out the upper interior cover to release it
with same screwdriver. Then use a socket to remove the bolt. (There is also
a small phillips/10 mm hex driver bolt near the top that you can access from
outside the car that holds the interior panel in place that needs to be removed
if you are going to remove the entire interior door panel.
Tip: once you have it removed use a piece of masking tape to hold all the
associated washers, etc. to the bolt so you keep them in the same order.
