TwinTurbo.NET: Nissan 300ZX forum - Faulty clutch slave cyl or master cyl or bleeding error??
Subject Faulty clutch slave cyl or master cyl or bleeding error??
Posted by fastertt on May 06, 2008 at 1:01 PM
  This message has been viewed 181 times.
Message While driving my slave cyl went out on me. I looked under and see brake fluid dripping from it and loss all pressure on my clutch pedal. I replaced the clutch slave cyl, put new fluid in it and bleed it.
After pumping my clutch pedal I get pressure from it with the car off. But once the car is started and engine running I lose all pressure again from my clutch pedal. I keep pumping the pedal and still lose. There are no more leaks under the car.
I shut the car off and pump the pedal and pressure builds. But once the car engine is on again I lose all clutch pedal pressure.
Whats wrong?? Did I not bleed it correctly. I've bleed it 3x now and still does the same thing. I only get pressure in my pedal when pumping it with the car off. Help please.
