TwinTurbo.NET: Nissan 300ZX forum - It's not too bad.
Subject It's not too bad.
Posted by Woody75 (Denver) on May 06, 2008 at 9:00 AM
  This message has been viewed 182 times.
In Reply To pass side window motor removal and replacement.. posted by apostrophe28 on May 05, 2008 at 08:15 PM
Message Once you get the door panel off take the front speaker housing out as well. Unbolt the glass from the track (might have to roll the window up and down to get in the right position). Once the glass is loose roll the window (track) down but pull the glass up to the top and have someone hold it there. Then you can look in and see where all the bolts are for the motor track. Unbolt everything and pull the whole assembly out the speaker hole area. Once out of the door you can see screws that hold the motor to the track. Just swap the motors and put it back together. Might want to regrease the window track while you have it out as well.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
