TwinTurbo.NET: Nissan 300ZX forum - Re: Falling fuel pressure
Subject Re: Falling fuel pressure
Posted by Noncon on May 05, 2008 at 9:01 PM
  This message has been viewed 221 times.
In Reply To Falling fuel pressure posted by Broke_as_**** on May 05, 2008 at 07:49 PM
Message Could be the pump itself, do a search here I'm sure someone else had a similar problem. The pump moter could ohm check good, but the internal seals could be bad causing low fuel pressure.
Make sure you are following the correct procedure to check fuel pressure, it should be around 35-40 psi with engine at operating temp and in the correct idle range (800-900 rpm).
KJ
