TwinTurbo.NET: Nissan 300ZX forum - What does the coolant temp sensor read out?
Subject What does the coolant temp sensor read out?
Posted by Ashman2k2 on May 05, 2008 at 5:44 PM
  This message has been viewed 185 times.
In Reply To 2 issues that I have been having posted by cossiemodo2000 on May 05, 2008 at 03:08 AM
Message Make sure the harness connector is making flat contact with the ecu, sometimes if the bolt is tightened to much the outside edge stick out.
When you say the boost gets stuck at 10 then jumps to 15, do you actually feel the extra boost come on? if you don't feel it act the way it shows then it may very well be the gauge itself.
Also I would check the readouts on the MAF, how are the o2 sensors?
