TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Stopped cranking
Subject Re: Re: Stopped cranking
Posted by gm on May 04, 2008 at 10:47 PM
  This message has been viewed 138 times.
In Reply To Re: Stopped cranking posted by Noncon on May 04, 2008 at 09:05 PM
Message ECU diagnostic was 55 before running the engine. After stopped the engine because of the smoke was 34 as I described before. The detonation sensor problem should not cause this problem and I'm wondering how effective the ECU self diagnostic is. How can you tell if ECU is faulty?
The symptom is that the moment the engine fires in a split second it dies. So, it seems some electrical problem. EFI Wiring is brand new and I believe it was wired correctly since it was idling OK. Compression is all within the spec.
