TwinTurbo.NET: Nissan 300ZX forum - Re: Pull codes from the ECU as a starting point.
Subject Re: Pull codes from the ECU as a starting point.
Posted by arthoes on May 04, 2008 at 6:27 PM
  This message has been viewed 107 times.
In Reply To Pull codes from the ECU as a starting point. (n/m) posted by Dave N on May 04, 2008 at 03:04 PM
Message Ok im an idiot. i had everything hooked up but the CAS. witch i had to change out because i had a old cas on and needed to install my new one and missed it due to my boost hose hiding the connection.
So now she fired up but idle is high as hell like 3k so need to readjust throttle cable and then timing. but im making progress =)
