TwinTurbo.NET: Nissan 300ZX forum - Appropiate bearing clearences??
Subject Appropiate bearing clearences??
Posted by Norz on May 04, 2008 at 12:16 PM
  This message has been viewed 112 times.
Message Hi
I am at the time reassemblying my engine and I just need some confimation on my rod bearing clearences.
I just measured them today and the clearences on 4 of them was
between 0,054mm and 0,074mm the remaining two was just a little under 0,054mm
the service manual says limit 0,09mm so this should be ok yes?
Also is it ok to have these differences between the different rods?
I am going to run gt525`s on my new build so my hp level should not be much higher than 420 whp.
what is the correct clearences for theese hp levels? Same as standard?
Thanks
  • Appropiate bearing clearences?? - Norz 12:16:00 05/04/08
