TwinTurbo.NET: Nissan 300ZX forum - I have nooo power!! Help??
Subject I have nooo power!! Help??
Posted by irieblue on May 04, 2008 at 10:57 AM
  This message has been viewed 179 times.
Message Ok so my 95 N/A Z has been giving me problems for a while...it started getting sluggish and backfiring so I did the 60k maintenance at about 80k miles ( I don't think the previous owner had done it when I picked it up from him at 70k miles).
I drive for a while but still no power, I check the codes again 55 all clear but no power... I seafoam the throttle body and use an inductive timing light and get about 13 degrees BTDC which should be ok but I still have no power... as in my mom's 10 year old minivan would probably smoke me ( I know its REALLY SAD). Yesterday I checked my codes and I have 34 again... I don't know if its related to the Seafoaming because that was only a few hours before. So I'm totally confused because I thought if code 34 was causing retarded timing I would have seen a number way off from 13 degrees. My electricals look pretty good I checked the TPS and CAS connectors and as I said the power drop is immense....Someone help me??
Also I was just wondering if there was someway my mechanic who did the 60k could have messed up something with the timing because he is experienced with Nissans but does not seem to like working with the tight spaces of my Z...
The only mod I have is a pop charger
