TwinTurbo.NET: Nissan 300ZX forum - 4000cfm ashtech electric fan did not cut it for me in
Subject 4000cfm ashtech electric fan did not cut it for me in
Posted by SpecNATT (Houston) on May 03, 2008 at 4:58 PM
  This message has been viewed 166 times.
In Reply To I suggest flushing the engine coolant lines and radiator posted by Waggz on May 02, 2008 at 03:48 PM
Message houston texas. with a koyo, and low temp thermostat. Went back to stock fan and shroud and problem fixed. Electric fans are the suck.
also make sure the aux condensor fan is working.
electric radiator fans dont flow enough with A/c on a/c condensers dump heat of around 130 degree in front of the radiators. normally a clutch fan would heat up, tighten up, and pull more air though. Electric fans don't do this.
cutforsig
