TwinTurbo.NET: Nissan 300ZX forum - To add a little more detail...
Subject To add a little more detail...
Posted by rojoloco (San Diego) on May 02, 2008 at 10:21 PM
  This message has been viewed 179 times.
In Reply To Confusing idle. Tomorrow is my last chance to fix it. posted by rojoloco (San Diego) on May 02, 2008 at 09:54 PM
Message When I started her up today to test her out, she started up a little rough and then seemed to run fine. I assume the rough start was fuel working its way. I let her idle for a short bit (around 1,100 RPM's) and then tapped the gas a little. As soon as I hit the pedal, she sputtered and then dropped out.
I started her up again and that is when the low erratic started back up. I found it to be odd that the car would run fine until the gas was applied and would then screw up.
Never Play Leapfrog With A Unicorn!!!
Do yourself a favor and just worry about your own car. I don't see what everyone is so worried about anyway. If someone else wants to perform a modification that you believe will destroy the value, cheapen the Z32 or whatever you can't sit on your hands about, wouldn't that make your tastefully-modified, white bread Z32 more rare and valuable? -- BradZ (FL) on December 23, 2007 at 12:19 PM
The unicorn gets its revenge... -- Scotts94z32 on September 19, 2006 at 11:12 AM
CLICK TO PURCHASE THE ZAMA STORAGE FACILITY POSTER!!!
