TwinTurbo.NET: Nissan 300ZX forum - Check the AAC valve is actually working as well
Subject Check the AAC valve is actually working as well
Posted by Audioquest on May 02, 2008 at 1:27 PM
  This message has been viewed 123 times.
In Reply To Idle fluctuates and safety boost problems posted by 93DemonCar on May 02, 2008 at 09:59 AM
Message as if the Coolant Temp Sensor is in spec.
The ECU might be a problem. If it's not bought to support 555's you will need to change that when you install the injectors. If it was and you haven't put the injectors in yet, it will think that's what's in there and be delivering an incorrect amount of fuel.
