TwinTurbo.NET: Nissan 300ZX forum - Idle fluctuates and safety boost problems
Subject Idle fluctuates and safety boost problems
Posted by 93DemonCar on May 02, 2008 at 9:59 AM
  This message has been viewed 151 times.
Message I have been chasing two problems for a while.
Once it reaches normal temp, the idle fluctuates between 500 – 1100. I have been running in safety boost for about 3 months.
I wasn’t too concerned because the injectors were getting flaky and was getting ready to putting in 300 degree rail w/ Nismo 555. I also put in a Ash Spec ECU and a set of Iridium plugs.
The rails are in, ECU shows a 55, timing is at 17 degrees, boost leaks have been found and fixed. TPS was replaced, the wiring harness was replaced about a year ago and all connections cleaned, O2 sensors replaced.
Any suggestions would be appreciated.
