TwinTurbo.NET: Nissan 300ZX forum - Re: Can ECU flash codes be wrong about PTU failure?
Subject Re: Can ECU flash codes be wrong about PTU failure?
Posted by Noncon on May 01, 2008 at 7:43 PM
  This message has been viewed 343 times.
In Reply To Can ECU flash codes be wrong about PTU failure? posted by bobluhrs on May 01, 2008 at 01:00 PM
Message No surprise there is a code stored, the engine just shut down.
There is no specific ECU code for PTU failure. If you try and start the engine over and over (like you would after a PTU failure) you could get a code 11 for CAS because of possible loss of 1 deg and 120 deg signal, but it will toss that code even for almost dead battery too.
Either way, if it did this before and after the alarm install, sounds like the PTU may be bad.
KJ
