TwinTurbo.NET: Nissan 300ZX forum - The PTU failure happened when the car got too hot when
Subject The PTU failure happened when the car got too hot when
Posted by doug8867 on May 01, 2008 at 4:39 PM
  This message has been viewed 454 times.
In Reply To Can ECU flash codes be wrong about PTU failure? posted by bobluhrs on May 01, 2008 at 01:00 PM
Message running and would then shut down, the car would not start until the PTU
cooled down. This usually took 15 or more minutes, not seconds.
Based on what you've posted in the past, your problem likely stems from a
wiring problem with the alarm installation and not PTU failure as you don't
have those symptoms. Not knowing exactly what was done all bets are off
on what the problem is.
You can refer to the ECU pin out diagram in the manual, section EFEC
near the back, pg. 172- 177 (I believe I posted the link to the online manual
for you in an earlier post) and start testing continuity to the various
components from the ECU to try and narrow down if you got a problem
with the signal not getting through. A tedious process to say the least.
However, if it was me I would call the company out who installed the alarm
and have them put the car back to stock where the car ran normally and
have them start over. Since you didn't have the problem prior to them
working on the car and now you do it obviously points to something they
did when working on it.
Good luck.
