TwinTurbo.NET: Nissan 300ZX forum - If, after performing the above proceedure, your timing
ZTicket(Dallas)
on May 01, 2008 at 8:18 AM
If your car was indeed detonating, a properly working
posted by doug8867
on April 30, 2008 at 09:30 PM
has NOT changed and you are NOT in safety boost, maybe just maybe, your pre-cats or main cats have come apart and the cat material is rattling around in the pipes. It has happened to me and it sounds similar to what you've described.
Rattle noise with throttle
nismoniac
15:42:25 04/30/08
Impending engine failure if ignored due to preignition.
Audioquest
15:58:26 04/30/08
Re: Impending engine failure if ignored due to preignition.
nismoniac
16:22:33 04/30/08
Sort of..preignition, not detonation. Regardless
Audioquest
16:28:04 04/30/08
Re: Sort of..preignition, not detonation. Regardless
nismoniac
16:32:21 04/30/08
What plugs do you use? They should be the stock NGK
Audioquest
16:45:02 04/30/08
Running NGK (1 step colder - 6?) Car is SPG Stage V
nismoniac
16:51:54 04/30/08
What EPROM is in your ECU that you "ran programming
Audioquest
19:39:48 04/30/08
doug8867
21:30:15 04/30/08
If, after performing the above proceedure, your timing -
ZTicket(Dallas)
08:18:09 05/01/08
I had SGP gut precats and I'm running test pipes in lieu
nismoniac
10:11:07 05/01/08
Get a timing gun and save some money.
doug8867
11:09:43 05/01/08
