TwinTurbo.NET: Nissan 300ZX forum - Re: Perhaps you could try adjusting the clutch pedal. There is
Subject Re: Perhaps you could try adjusting the clutch pedal. There is
Posted by zxr8ted300 on May 01, 2008 at 7:14 AM
  This message has been viewed 90 times.
In Reply To Perhaps you could try adjusting the clutch pedal. There is posted by 5280Z_nightstalker on April 29, 2008 at 10:34 AM
Message :a write up in FAQ La-Z-Link
It is not the adjustment of the pedal.As I stated the clutch is perfect until I turn the car off for the first time after initial crank up.Yesterday I found that if I pull the cap off the reservoir,it pops there is so much pressure,then my clutch is back to normal.Is it a bad booster?
