TwinTurbo.NET: Nissan 300ZX forum - My vote on cause: Fan Clutch
Subject My vote on cause: Fan Clutch
Posted by Thomas+10 on April 30, 2008 at 9:00 PM
  This message has been viewed 85 times.
In Reply To Overheating(need suggestions) posted by JW300ZX on April 29, 2008 at 02:50 PM
Message Belt tightness, fan clutch, system seal (no air leaks like from heater valve or radiator cap pressure relief or "cracked top radiator tank around hose connector or parallel to front or rear of top plastic tank), thermostat failure (my experince with other cars rather sudden and not remedied by cooling off engine by shutting it down and running it later but is possibility). Fan clutch symptom - car runs fine at speed but heats up when stop and go required and least likely to be detected by movement of fan by hand.
S+10
