TwinTurbo.NET: Nissan 300ZX forum - What plugs do you use? They should be the stock NGK
Subject What plugs do you use? They should be the stock NGK
Posted by Audioquest on April 30, 2008 at 4:45 PM
  This message has been viewed 169 times.
In Reply To Re: Sort of..preignition, not detonation. Regardless posted by nismoniac on April 30, 2008 at 04:32 PM
Message Platinum PFR6B-11B gapped to .035 and timing at 15.
Do you have an EBC or jets? I'd check the above, back the boost off to 13 and see if it still does it.
Weak injector, fuel pump, clogged fuel filter, air temperature can also contribute to this.
I'd say 15 PSI might be on the high side and would personally go 14 to be safe that sorry.
