TwinTurbo.NET: Nissan 300ZX forum - Re: Impending engine failure if ignored due to preignition.
nismoniac
on April 30, 2008 at 4:22 PM
posted by Audioquest
on April 30, 2008 at 03:58 PM
So you agree with detonation assumption then?
Rattle noise with throttle
nismoniac
15:42:25 04/30/08
Audioquest
15:58:26 04/30/08
Re: Impending engine failure if ignored due to preignition. -
nismoniac
16:22:33 04/30/08
Sort of..preignition, not detonation. Regardless
Audioquest
16:28:04 04/30/08
Re: Sort of..preignition, not detonation. Regardless
nismoniac
16:32:21 04/30/08
What plugs do you use? They should be the stock NGK
Audioquest
16:45:02 04/30/08
Running NGK (1 step colder - 6?) Car is SPG Stage V
nismoniac
16:51:54 04/30/08
What EPROM is in your ECU that you "ran programming
Audioquest
19:39:48 04/30/08
If your car was indeed detonating, a properly working
doug8867
21:30:15 04/30/08
If, after performing the above proceedure, your timing
ZTicket(Dallas)
08:18:09 05/01/08
I had SGP gut precats and I'm running test pipes in lieu
nismoniac
10:11:07 05/01/08
Get a timing gun and save some money.
doug8867
11:09:43 05/01/08
