TwinTurbo.NET: Nissan 300ZX forum - Re: EGR and AIV ?
Subject Re: EGR and AIV ?
Posted by ali300zx on April 29, 2008 at 8:48 PM
  This message has been viewed 242 times.
In Reply To EGR and AIV ? posted by action on April 29, 2008 at 08:39 PM
Message [ www.thumper300zx.com ] is a good resource
egr:
middle of egr solenoid goes to egr valve
top vac. line of egr solenoid goes to bottom of the vacuum gallery running along the passenger side of plenum. then on other side, it goes to turbo inlet pipe (accordian pipe).
bottom vac line goes to top of vacuum gallery " " ". then on other side, it goes to the throttle body nipple.
aiv.. not sure, should just "T" into the other remaining lines and go to balance tube. or just delete that solenoid and lines if you have a chipped ecu.
