TwinTurbo.NET: Nissan 300ZX forum - Overheating(need suggestions)
Subject Overheating(need suggestions)
Posted by JW300ZX on April 29, 2008 at 2:50 PM
  This message has been viewed 173 times.
Message This weekend I went for a drive in 98-105 weather.
All was well until I got stuck behind a slow moving vehicle. The temp slowly climbed from 1/2 to about 4/5 when I pulled over and let it cool. The rest of the drive was fine unless I was at a stop or slow speeds.
The AUX fan does not seem to be turning on. It is supposed to come on when running the AC correct? I removed the nose panel and ran the car at idle with the AC on and the fan was not moving.
I checked the clutch fan by spinning it by hand and it would turn about 1/5 of a rotation.
Coolant levels are fine and I have no leaks.
I plan to flush out the system this week to see if that helps. The radiator itself looks a little dirty but I can't see any large debris.
I am thinking the AUX fan is the main problem but I just wanted some other opinions since I am still very new to this stuff.
