TwinTurbo.NET: Nissan 300ZX forum - Update: Sprocket Puller
Subject Update: Sprocket Puller
Posted by Thomas+10 on April 29, 2008 at 12:39 PM
In Reply To Timing Belt Gear Removal Problem posted by Thomas+10 on April 26, 2008 at 09:29 PM
Message Used a small drill to drill two small diamiter holes then a little bit larger drill to widen the holes. Threaded holes and put thin bolts in and attached to puller. No problems with puller.
Had to break second drill to get enough room between heat exchanger for AC and sprocket.
Thanks to this site for information.
Timing Belt Job complete.
Ton S.
S+10
