TwinTurbo.NET: Nissan 300ZX forum - Car Not Starting... Stumped Very Long.. Sorry
Subject Car Not Starting... Stumped Very Long.. Sorry
Posted by S13Josh on April 27, 2008 at 12:15 PM
  This message has been viewed 154 times.
Message Ok so Ive been searching and trying Different things to solve this without posting anything on here... So here it goes,
I recently did the timing belt and upgraded my turbos, injectors, ecu, and a few small things like head gaskets. After the Timing belt i double and triple checked it before putting it together and turned the motor and there was no interference... I put all the other goodies on and dropped the motor back in... The car will not start now and i ran through all the things i could find on here with fuel and ignition(cleaning connectors and so on) I belive the car is not getting fuel due to the facts that it only sounds like its firing on 1 cylinder and that when i sprayed starting fluid it decided it would run(for a few seconds)
I believe the fuel pump and controller are coming on as there is fuel to the injectors and i ohm tested the injectors and there all consistent at 12-14 ohms. I am stumped here and am wondering if any body can give me some guidance and what to try next. Sorry so long and thanks in advance
Josh
