TwinTurbo.NET: Nissan 300ZX forum - Make sure you're getting enough fuel.
Subject Make sure you're getting enough fuel.
Posted by yobobrox on April 26, 2008 at 10:07 PM
  This message has been viewed 168 times.
In Reply To car breaks up in every gear at 5-5500rpm posted by Antonio(AZ->NYC) on April 26, 2008 at 07:56 PM
Message Check fuel pressure if you don't have wideband o2. It's probably from lack of air or ignition, but check the fuel first unless you're positive it's not running lean. You don't want to risk engine damage.
Run ecu codes.
Then, do a leak test. Be aware that pcv valves/hoses can leak under higher pressures that only shows up when under heavy boosting (from what I've seen).
Then try putting back recircs or other blowoff valves.
Then swap cas.
Then swap ptu.
If that doesn't get it, I'll be amazed. Keep us updated.
