TwinTurbo.NET: Nissan 300ZX forum - That's not the drive shaft
Subject That's not the drive shaft
Posted by ZXRider(SoCal) on April 26, 2008 at 9:45 PM
  This message has been viewed 149 times.
In Reply To Timing Belt Gear Removal Problem posted by Thomas+10 on April 26, 2008 at 09:29 PM
Message it's the "crank shaft"
The cam shaft seals and the front crank shaft seal the same. If you mixed them up don't worry about it as the 4 front camshaft seals and the front crank shaft seal is the same.
The piece you are trying to remove is called the crank sproket. If you have seen the timing belt write up on here, it is mentioned that they become siezed and hard to remove. At this point don't risk damaging the oil pump and don't wedge a screw driver between the sproket and the pump. You need to purchase a die air grinder or a dremel tool with 2" cut off disks and cut that sproket off. Make sure you DON'T knick or damage the crank shaft. You need to make a slit down the sproket and wedge a screw driver between the slit and break the sproket.
A new sproket will cost you $20.
Don't tap it in toward the engine.
I have nightmares about that happening...I'd be the poor bastard you'd hear about on the news that gets killed by a softball-size chunk while spreading out my body over the hood and screaming "Nooo!" (Having a conversation about hail damage) - BradZ (FL) on March 25, 2005 at 9:56 PM
Tell your friend that you could take a dump, light it on fire and that would be hotter shit than his car. Probes suck, that's just all there is to it. - 300ZXpert (someday) on April 04, 2005 at 11:35 PM
P.S. You REALLY are on here at ALL hours! And I thought I was bad! :) - zmenon on August 16, 2005 at 3:06 AM
LOL...2+2 drivers should grow mullets..."Business in the front...party in the back" ;) - BradZ (FL) on November 29, 2005 at 4:45 PM
