TwinTurbo.NET: Nissan 300ZX forum - Timing Belt Gear Removal Problem
Subject Timing Belt Gear Removal Problem
Posted by Thomas+10 on April 26, 2008 at 9:29 PM
  This message has been viewed 232 times.
Message Am doing timing belt cam seals and main seal maintenance but have not been able to get the gear on the driveshaft to budge. Soaked with PB Blaster a few times and wedged a few screwdrivears between oil pump case and back of gear. There must be an easeir way to do this. Everything else has gone fine. [damaged one seal for cams and mixed one cam seal with front main seal and can't tell which is which] but I don't think it matters until I get the gear off the drive shaft.
Mabe tapping it in toward the engine will loosen it?
Need help.
Thanks,
Tom S.
S+10
