TwinTurbo.NET: Nissan 300ZX forum - I think a problem with the harnesse is not what's
Subject I think a problem with the harnesse is not what's
Posted by jzack on April 26, 2008 at 4:37 PM
  This message has been viewed 193 times.
In Reply To Help - Replaced PCV Valves and Hoses, now car won't start posted by ooofoo on April 26, 2008 at 04:16 PM
Message causing this issue. My guess would be a bad battery connection - you sure the new battery is fully charged? Do the car's hi and lo beam lights work? Did you measure the battery's terminal voltage?
Also inspect the ground connection just behind the battery's negative terminal. It's a bolt down point to the firewall -- often the battery cable freys there and the cable can't supply enough current to the car for hi powered things (like a starter - but you could get dash lights, etc)...
