TwinTurbo.NET: Nissan 300ZX forum - Help - Replaced PCV Valves and Hoses, now car won't start
Subject Help - Replaced PCV Valves and Hoses, now car won't start
Posted by ooofoo on April 26, 2008 at 4:16 PM
  This message has been viewed 199 times.
Message I just completed replacing both PCV valves and hoses. I've reassembled everything, but when I go to start the car it won't crank. I also replaced my battery while doing the passenger side PCV. I've check the fuses in front of the battery and everything seems to be in good order. Fuses under the main fuse box also seem to be fine.
The wiring harness did take somewhat of a beating during the PCV install, especially when trying to remove the vacuum ports out of the plenum on the driver side. More specifically, the plastic that the harness is routed inside got cracked, but that's about it.
I'm thinking it's an electrical problem. Fuel pump not receiving power?
Any help or suggestions would be greatly appreciated.
-Throttle position sensor is connected.
-Idle air tube connected.
-New brake booster hoses installed.
